Max-4's avatar
Max-4
Please help with solar and electrical questions...
Hello, first of all let me say a big thank you for reading my questions, I am new to RV'ing and im trying to pick things up quickly. My wife and I just put a downpayment on a brand new 2022 Forest River Salem FSX 177bh, we should take delivery of it in February or March of 2022. If I had to guess I could see my family using this trailer to do 70% plug in camping with full services and 30% off the grid boondocking. I do want the ability to use the trailer at National and Provincial parks (oh yeah im Canadian) where there likely wont be any water or electricity.
My dilemma is in regards to the fridge choices and solar packages that are available for this trailer. This Salem FSX comes with a new large ever-chill 11 cu ft 12v refrigerator standard. There is an option to go with a smaller 8 cu ft 3-way electric/propane fridge. With this option I would only have one group 24 battery that the trailer came with. I could also add another group 24 battery for a total of two but I would have no way of charging them once at campground. I do know the differences between these two fridges, I have been doing a bit of research.
My other option is to add the $850 solar package from the factory which includes a "Roof mounted 190 watt solar panel, 30 amp controller and battery". So am assuming this adds a second group 24 battery for a total of two after the one the trailer comes with. So I would have two group 24 batteries in my bank and the solar system to charge them. The dealer also recommended upgrading the two batteries to group 27 batteries at a cost of $280.
After reading a little bit it sounds like these new 12v refrigerators are pretty efficient and dont draw too much. I want the ability to go off grid for 48-72 hours and run the fridge as well as lights, stereo and charge devices. I understand this is dependant on sunshine and our usage but do you think its possible? the ad on ever-chills website said the fridge is sustainable with a 200 watt solar pannel and two batteries.
What would you guys recommend for my needs? I am kind of hoping that we can get by with the larger 12v fridge, solar package and two batteries in my bank. Thanks in advance for your time!!!
  • Gjac's avatar
    Gjac
    Explorer III
    If you boondock 30% of the time I would stick to the el/propane refer forget the solar for now and get 2 6v GC batteries. You will have more than enough power for 3-5 days dry camping if you just camp in the NP's. If you have don't have to watch TV our play video games or use electric devices while dry camping. As a data point I dry camp only and in 7 days my 2 Sams club batteries are down to 50% SOC without solar or genset usage. The limiting factor is water in 7 days my 60 gal tank is almost empty and it is time to do laundry. How much water is in your trailer? With kids you will probably run out of water before battery power. The other thing to consider is the size of your gray tank, even if you can carry water from a GC faucet, US NP's don't allow you to drain gray water at your camp site I doubt Canadian NP's do either.
  • For as little as you're going to boon dock, there is prolly not much reason to go with a propane fridge. I would absolutely NOT waste you money on a factory solar package. Just throwing money out the window. Get a couple 6 volt golf cart batteries, and a portable solar will possibly get you thru 3 days of off grid. We boon dock almost exclusively and rely entirely on 12v and propane, with 450w of solar charging four 6v golf cart batteries. We have a generator for emergencies, but never have used it. I think the DC to DC chargers are a real good thing to have too.
    Welcome to the forums!
    Definitely go with the 12 volt fridge.
    I would add a dc to DC charger for use when towing. One with a 20 amp output will serve you well and make sure you arrive with a full battery bank. https://www.amazon.ca/Renogy-Battery-Batteries-Multi-Stage-Charging/dp/B07Q5VYPCF/ref=asc_df_B07Q5VYPCF/?tag=googleshopc0c-20&linkCode=df0&hvadid=335950807635&hvpos=&hvnetw=g&hvrand=743853709765311581&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9001253&hvtargid=pla-728968810259&psc=1
    $950 is a rip off price.
    If you are "handy" with tools you can do MUCH better.
    This series of articles may help you "size" the solar system:
    https://freecampsites.net/adding-solar/
    They have a pretty good trip planner, too (and yes there are lots of Canadian sites listed).
    Most Federal Parks do have power. Many of the Provincial ones do too. Ontario is famous for needing LONG extension cords. The exception is BC where few of the Provincial parks have power.
  • Remember, solar doesn't do well when under shade trees. Unless your off grid locations will have a lot of sun exposure, you may come up short.
    You can do a lot better than $800 for 190 watts and the controller.
    I'd suggest an after market approach on the solar, 200-300 watts and use the extra money for a small generator for the time that clouds and rain stall your charging.
  • jdc1's avatar
    jdc1
    Explorer II
    Buy your batteries (2-6 volt golf cart) at Costco or Sams Club. Buy and install the solar yourself (it's very easy to do). Get a QUIET 3,000w+ inverter generator. Now you can stick to the 12v fridge.....and run your AC.
  • I would go for the larger fridge as well, whether to have them install the over-priced solar and battery setup is your choice. Might be wise to have it done aftermarket using better components, a pair of 6 volt golfcart batteries, and more than likely end up with additional wattage for what they are charging.
    Most factory installed systems tend to utilize less than ideal equipment and wiring. For best results when RVing off the power grid is to have a quiet inverter genny along with a fast charging smart converter for times when solar can't keep up. Congrats on your new rig, welcome to the RV lifestyle.
