rasta's avatar
rasta
please help with wd hitch
this is what happens to my hitch everytime i tow, teeter tottering down the freeway. the truck will lower 2inches in rear when all weight on ball as seen in pics. bars are bent up too much i know. can only get truck rear to raise 1 inch after getting chains tight. its a 10000k wd hitch. do i need to adjust ball height? i have no clue what to do, thanks for any help.
  • i think you found the problem, thanks, i set up the top of hicth and ball flat. never thought to angle it down. been towing for years teeter tottering down the freeway like a fool. i will post again once i mess with it tommorow
  • How about some more info on what you have and a wider shot of the truck and trailer connected? We can't see how everything sits with the closeup picture.
    Offhand, I'd say that you need to tilt the hitch head w/ball back at a steeper angle but I don't own that hitch.
