GoDawgs
Jul 27, 2016Explorer
gbopp wrote:
Wouldn't a couple coats of varnish have the same result?
It seems to me that if a couple drops of water got behind the plexiglass, it could be a breeding ground for mold. JMO
I'm not sure how the faux wood finish would react to the varnish. As for the mold, I agree, which is why I'm looking for some type of caulk to adhere it to the cabinet. I plan to cut the acrylic to fit as tight as possible and then caulk around the edges to make it as waterproof as possible to prevent mold/mildew. I was planning to just silicone all the way around, but from what I've read, silicone doesn't bond to acrylic. I'm sure I'll need to remove and clean, which is why I'm looking for a semi-permanent fix.
