Thom02099
Jun 17, 2015Explorer II
Sandia Man wrote:
The 2 links you provided do indicate that these power tongues jacks are capable as they include the seven pin plug if that's the route you want to go. Easily one of our favorite mods, our battery is directly behind our powered tongue jack and it was much easier to just attach the single wire to the positive post. Enjoy your new powered tongue jack!!!
Thanks for the input, that was my thinking as well. I'm really more inclined to go with wiring direct to the battery with Jack Quick as the simple solution. The drawback I see from going with that "plug and play" unit is that there could be times when you may want to raise/lower your trailer and your TV is not readily available. Using the on-board battery resolves this. Just thought the plug and play design was interesting.
44,067 PostsLatest Activity: Jun 05, 2026
