BurbMan
Jan 07, 2014Explorer II
westend wrote:
I think some folks have bad luck with plugs because of bad installation technique or using a cheap plug.
Bingo! A plug when done correctly with a quality plug, mushrooms out on the inside of the tire and is designed to seal the hole from the inside also. It can't "shoot out like a bullet." That's only if you use a good plug made from good material with good adhesive. A cheap or improperly installed plug will leak over time.
44,027 PostsLatest Activity: Apr 19, 2019
