VickieB68's avatar
VickieB68
Plumbing HELP..?
Bought a 1995 Skyline Boomer, M2010. It has to be replumbed as all the lines leaked antifreeze when I attempted winterizing. I can not locate any information on this camper.
Does anyone know if the water lines from the front fresh water tank to the rear water heater run underneath the wetbath or along the wall behind the wetbath? I am wondering if I pull out the wetbath back wall whether I can get to those lines and find leaks.
  • For a complete replumb I would go with buying the crimper and crimp sleeves over sharkbites.
  • Thank you. I have already checked into Pex & that seems the best choice. The sharkbite fitting are very expensive so I'm debating those.
  • Pianotuna: Thank you. All the water lines are inside the camper. So, do I run new lines and just ignore the old ones and leave them in place? If room, I see no problem doing that.
  • VickeB66,
    Simply run new lines made from Pex. Then there will be no leaks--and you can route the lines inside the heated area of the RV.
    The lines can be "fished" past obstructions.
