Pauljdav's avatar
Pauljdav
Pocket door stuck in wall
My bathroom pocket door is stuck in the wall. The rear wheel came off the track.
Is this repairable without taking the wall apart?
Has this happened to anyone here?
What was the cost to fix?
Thanks all for any assistance!
Paul
  • If the rear wheel just came off the track, you should be able to work the door out of the pocket. And then rehang it.
    Another not uncommon problem is that sometimes the screws holding the door track at the most inside part of the door will come loose from the ceiling and let the track (and door) drop down inside the pocket. This happens from the constant pounding that takes place while going down the road. That is more difficult as access to the pocket is very tight and hard to put the screws back in. Mine did that. My pocket door is behind my entry closet. And the entry closet has an access panel in the back wall. I was able to work a screw driver with magnetic screw tip holding a screw up thru the opening to put screws back in the track. Some with no other access have posted how they used a cordless drill with a very long home made extension to hold screws as they reached up thru the pocket opening to put the screws back in.
  • Our pocket door has fallen off a few times. I was able to slide it out, look at how the wheel attached to the track and get the other one reattached and locked to the track. Now it stays in place.
  • You should be able to remove the door by taking off one of the trim pieces at the top. Once off the track you can make repairs and then reinstall the door onto the track and into the pocket. I did that with mine and the repair has lasted as long as the rv has.
