trailernovice's avatar
Jan 28, 2019
poor frame design
Just traded a 2016 Crossroads Zinger Z1 252BH for the TT in the signature...
I didn't realize until after the Crossroads purchase that it has a poor frame design...instead of the hitch coupler coming straight out of the trailer frame rails, the coupler is underhung from the frame...the only advantage I can see is it makes it easier to step over the hitch when hooked up...the big DISadvantage is that it sits so low that there's only about six inches or less of clearance between the bottom of the hitch and the roadway...w/d bars scrape on every intersection 'dip', every gas-station entrance with an incline, etc....that's a big reason I decided to ditch the Crossroads...
something to be aware of when looking at units
Interesting...I just looked at the current Zinger line, and it appears they've changed to a 'straight from the frame' coupler rather than the previous underhung design...guess I'm not the only one who saw this as an issue
  • Personally, I think the design of being under the frame is much stronger and less likely to bend if the hitch hits the ground hard.
    I've had both and prefer the latter.
    I can understand it being too low for some trucks though.
    Arctic Fox with it's "Off road rated frame" alway puts it under.
