Manwithoutoptio's avatar
Sep 30, 2018
Poor man's build-in generator for long box AF865/811(?)
It turns out there is a generator(A generic chinese brand. Comes in many name in the states, earthquake, sportsman and homegear) that can fit in the long box of Arctic fox 865/811(?).
Pictures
I cut the bottom flap with a reciprocating saw into multiple pieces and just introduce metal fatigue with pliers by wiggling the extruded pieces, took out the generator covers, and cut the handles on the generators (probably not needed, but I was desperate to get it in). Then I cram it in panel side first upward and just turned it to face the start pull outside.
and there it is! nicely tucked inside the safety of my camper. 700W wont run the microwave/AC but my LiFePO4 battery/inverter can. It is just there for backup in case solar doesn't pan out. I cannot believe it worked out so well at the end.
It does need extra fan to assist combustion. But the generator does come with 12v and 5v. I will rig some 3dprinted part + brushless DC Fan and embed them into the door later.
  • You are overlooking the fact that factory generators are design for RV, have powerful fans and regardless RV original design, all I have seen mounted on TC have additional exhaust pipe extensions.
    Do you plan exhaust extension? We have lot of topics about fitting different generators and the Venturi exhaust going over the roof sure is good design.
  • Rather amusing to see you two would see fire or fume to be an issue. This room originally is suppose to be the generator room. However Northwood offer a long box version of these 2 campers to increase stability by sacrificing generator space. It just so happen that this particular generator is small enough to fit into the stunted room.
    Hope this clear things up.
  • That looks close to the generator I bought at Home Depot sale for $150.
    Mine is rated at 1000 W peak thought.
    I would worry more about fumes than fire with camper mounting.
    The generator 12V outlets usually deliver "dirty" power. Good for emergencies, but for everyday use, better get automatic charger.
    For me the small generator is back-up as when I camp, I need to carry 3000W for AC.
    Love the 20lb weight and small size. I keep it on the truck 2nd row floor most of the time. Can take it on boat as well.
    That thing really sips fuel as I experienced when the house power went out for most of the day and it will run my smaller micro and coffee maker.(not at the same time)
