dodge guy wrote:
Even if they supplied you with wiring and plumbing schematics.......good luck in figuring out how they actually ran everything. wire colors would be different, plumbing would be completely different let alone the fact they can screw up the most basic of connections.
Consider yourself lucky if all the systems function on a new trailer properly....if at all!
Oh God, you should see the rats nest of wiring behind the instrument panel of my boat. :R
The gas gauge quit working and after a couple of tries I just had to give up. I know I'm out of gas when the engine quite running. Sucks too. I just keep dumping a gallon in now and then and hope for the best.
