donn0128 wrote:
Let the scales become your new best friend. Stop guessing and get accurate weights.
In addition to this.
Verify all of the various ratings (GVWR, Payload (AKA occupant / cargo capacity), GCVWR) on your particular truck. Keep in mind, manufacturers max tow ratings are an "UP TO XXXX lbs when properly equipped" number. Those numbers do not include aftermarket accessories (undercoating, bed liners, bed covers, step bars, tool boxes, etc), passengers, or cargo. Each and every truck will vary, depending on how it is equipped and how it is loaded. Adding weight from accessories, passengers, and cargo, reduces the truck's true towing capacity.
If the manufacturer says the truck can tow up to 10,000 lbs, and your accessories, passengers, and cargo weigh 1000 lbs, your true max tow capacity is 9,000 lbs, and your available payload is reduced by 1000 lbs.
When you go for your actual weights, have the truck and trailer loaded (including water, if that is how you travel) as if you're going camping. You may find you are much closer to your max weight, than you think you are.
If you are still within your rating numbers, a few things that you can do to help with the ride are adjusting the WD hitch, adding Timbren SES, airbags, or helper springs, adding tire pressure (do not exceed max pressure printed on tire sidewall), or changing tires to something rated for a heavier load.
