al7601's avatar
al7601
Portable ice maker, anyone have one of these?
Insignia™ - 26-Lb. Portable Ice Maker
http://www.bestbuy.com/site/insignia-26-lb-portable-ice-maker-black/5466501.p?skuId=5466501&cmp=RMX
I have a $100 bestbuy gift card I have to use so naturally this is good fit but at the same time I'm not going to get it if its garbage.
I never had a portable ice maker and wanted to also know how long it would take for it to put out enough ice to keep a 30 pack of beer cold in a 48 quart cooler. I know temperature would make a difference outside but roughly.
  • I bought one this year at Home Depot. Tee controls are a bit different, but it's the same shape. It works great. One the one I have, the controls are on the top, making them easier to see.
  • We have had two over the years. One quit and the other was tempermental. We winter in Florida. We found the ice to be "soft"and seemed to melt quickly. We emptied the maker into gallon zip lock freezer bags and kept in freezer. Was a pain to keep making ice. If we were away from fiver, the ice would melt in maker. We finally bit the bullet and went to buying 10# bag and keeping in freezer. Life is better. If ice is low in freezer at nite, we make note to get another the next day. Cost of the ice is a non issue.
  • We have the small dometic and it does what we ask it too. If I remember correctly it will produce around 22 lbs of ice per day with cubes coming out every 8 mins.
  • Howdy!
    We purchased one made by Igloo. Worked great for about a year and a half. We will be purchasing another one but not a Igloo brand.
    "Happy Trails"
    Chiefneon
  • We have one. Got it on sale at Shopko. I love it. The only thing is when we put the ice it makes in the freezer, since the "cubes" are a little wet they freeze in a clump. It is the only thing the better half does not like. However, if you put it in gallon zip lock bags, you can drop them on the floor to break up.
    I too use bottled water to keep the hard deposits out.
    Since you have a gift card that will almost full pay it, go for it.
  • I've had about six of them before I ended up with two that work. The others were replaced under warranty. From what I've seen, I think they are all made by one or two companies and branded for the distributors.
    The two I have now, one for the house and one for the trailer work great. I've had them both for a couple of years now.
  • I have a new Avalon Bay ice maker... it's very similar to the link you added from best buy... It also producesee 26 lbs of ice per day in 2 different sizes cubes. I had to delay my rv travels due to a squirrel... lol... so ive been playing with it at home and testing it out... I will say for ice in drinks ect, it will work great. However to fill a cooler full of ice will be very tasking. You would have to stay on top of dumping out the ice every 8 to 10 minutes...and I just don't see the cold ice lasting long enough to stay on top of it... however if you prefilled the cooler with ice and just used it to top it off... this might be possible... but once again your a salve to the ice machine. I personally have 2 freezers in my rv.. and really would just use it for drinks, and can make enough to store while I'm out on adventure.. The ice mine makes is hard not soft at all... once again... if you stay on top of it...Hope this helps...
  • I've been using a large Mr. Freeze (Made by Maxi-Matic) for about 10 years. It works great. Lots of ice, fast. Downside is they are loud and the ice does melt. Cleaning the ice maker is a chore too. I believe Maxi-Matic makes most of the various branded models. I was able to order a replacement for a cracked drain plug without too much hassle also.
