DarbyWalters's avatar
DarbyWalters
Portable Power...mounting ideas
I have a Jayco White Hawk 29REKS with dual AC units...50 amp plug.
I am wanting to be able to camp without hookups on Port A Beach.
I am wondering if it would be feasible to "mount" a generator/invertor (something quiet) somehow on the rear bumper. I want it to be secure from easy theft.
Then I have to decide on size and fuel. On the beach, I would probably just use 1 AC unit, Flat Screen TV and Lights. The fridge and hot water heater could run off propane. If I got a propane generator, I already have a line run from the front bottles to a BBQ Grill hookup that we don't use.
I want to do this right and spend good money ONCE. Any suggestions/pics would be greatly appreciated.
  • I wouldn't do propane. Gasoline is on every street corner. Propane sometimes starts harder in cold weather just depends. I converted a Champion to propane and mounted it on my reinforced rear bumper of a TT. Noisy inside. Now I have a remote start Honda bolted in the truck bed with an insulated, ventilated metal enclosure. With the truck hood to the rv you cant hear it at all. My a/c is 30 amp though.
  • I would not put on the bumper. I have my EU2000 {2} sitting in the rear of my p/up bed. One on each side, locked with large chain. Unlock and slide onto tail gate when I use them. I have a p/up camper shell over the bed as I tow a TT I have alarm wired to rear of p/up at night if anyone comes around the rear of my p/up at night while camping
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Get yourself a nice 2000w Inverter genny like a Honda, Yamaha, or Champion, they're only about 45 lbs and either keep it in the back of your truck and plug in or move it by the trailer. Put back when not in use. I see no advantage to mounting it on the bumper. I run my Honda EU2000 on the ground at the back of the trailer secured with a cable and lock to prevent the quick grab. I lock it in the back of the truck under a hard tonneau when not in use.
  • Hadn't thought about warranty issues...still have 1 year and 3 months left.
    Hope this pic works mounts over the tongue and propane bottles. Holds 300#...could plumb a Propane Generator in easily at this location.
    http://www.etrailer.com/Trailer-Cargo-Control/Stromberg-Carlson/CC-255.html
    No window at front of trailer...bedroom tho.
  • Hi DarbyWalters. I also have a WhiteHawk and I don't believe that it's possible to mount a generator on the rear bumper as they're pretty "feeble". You might check this out. http://www.etrailer.com/Trailer-Cargo-Control/Stromberg-Carlson/CC-255.html?feed=npn&gclid=CKG_94TVisYCFQSUfgodC4AAtw
    If link doesn't work go to the etrailer site and look up Stromberg-Carlson. It's pretty cool.
    It's not impossible but a few things to consider;
    1) the rear bumper will have to be reinforced to handle the weight of a generator..welding a custom rack to the frame. It will void any frame warranty.
    2) the sound and vibration of an attached generator WILL be obvious inside the TT regardless of what genny you buy.
    3) be very mindull of exhaust fumes entering the TT from windows or vents from a genny running that close to yor unit.
