MMEvans's avatar
MMEvans
Portable Solar Panels
Hi! We are new to RVing and have a lot to learn! We have a 13 foot KZ Sportsman and we are interested in getting a portable solar panel so we can go places where electricity is not available. Anyone have a suggestion on what size/make we should look for? It is a small trailer and there are just 2 of us.
Thank you!
  • Might also want to take into consideration the physical size, weight of the panels for storing, moving and setting up..
    Higher wattage panels are pretty large to handle and get heavy quick, can make finding a storage space and moving them around a challenge.
    Laying them flat on the ground or partially open standing up, while it may work, may not be ideal for max harvest of energy leading to needing even more panels..
  • Portable solar panels = set up in morning (my roof mounted panels are already working), watch over, move around. Go to town for lunch after putting panels away (my roof mounted panels continue to work). Return from lunch and put panels out. Watch over, move around. Near sunset, put panels away. Repeat every day.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    renogy makes some nice folding portable panels, go for what you can store and afford, and all the portable panels I've seen have a PWM controller ON the panel you must keep the cable from the panel to the trailer as short as possible or charging current will drop like a rock. If you want a run longer than the cable with the panel remove the controller from the panel and mount it in the RV and run #12 or #10 wire from the panel to the controller.
    I have 3 renogy 160W portable panels and a MPPT controller, give us all the solar we need.
  • 200 watts minimum. Connect the controller close to the battery. Avoid all shade.
  • Go thru and estimate how long each electrical device will be expected to run. Then look on the label and find how many watts it draws while running (make sure to dig around and find everything that will be running).
    Multiply watts by duration and total up to get watt-hours.
    A solar panel that isn't shaded will generally produce 4-5 times it's rated wattage in watt-hours (ie: 100w panel will generate around 400w-hr).
    Assuming you will be boondocking mulitple days in a row, you will need sufficient panels to replace your daily usage.
    You also need a battery bank of sufficient size. If you will be using 600w-hr over the night and your battery bank only holds 300w-hr, doesn't matter what size solar array you have.
    PS: Lead-Acid batteries shouldn't be drawn below 50%, so start assuming only have the rating is available for use.
  • Might want to advise as to what you would expect the solar to support.
  • I use the Renolgy 100 Watt suitcase,comes with a nice case,easy to store.
    I made up easy plugins for it,easy to use and move around and keeps the batteries topped of nicely.
