- ADK_CamperExplorerI have used a bycycle pump which works fine but it is a bit of work! This past season I switched to a Harbour Freight 12V inflater. It has worked fine. It was very inexpensive, and I figure I've already gotten fair value out of it; every use going forward is a bonus.
- rider997ExplorerTry a Viair 12V compressor (many models available on amazon). Available in a variety of CFM including some continuous duty models. Fairly well built and easy to run off of TT or TV batteries. Permanently mountable models are available as well.
- facoryExplorerI carry one by Goodyear. It will pump up to 150# and has been able to up the pressure in truck tires. Runs on the TV's 12v system. It's with me all the time.
- 2oldmanExplorer II
- GrandpaKipExplorer IIHarbor Freight model with long battery leads and 16' hose. I can hook up to TT battery and get to all truck tires and TT tires. It's relatively quiet and quick enough, seems to be pretty well made. Time will tell.
- wmosesExplorer
Fresno Tundra Driver wrote:
I've gotten by with a bicycle pump for 12 years. :)
Popeye! :) - wmosesExplorer
mbutts wrote:
I bought a Slime Heavy Duty at Autozone. Nice to have the built-in gauge.
Slime
I have this one also. Works well but I only use the built-in gauge to get me to the approximate stopping point (just over) before disconnecting and final checking the pressure with a proper digital gauge. - RoyBExplorer IIIFor me the Q Industries MV50 Portable 12VDC Portable Tankless Air Compressors (AMAZON) works just fine. I can air-up my trailer and truck tires and also use it for blowing out my water lines in the trailer when the temps drop below freezing...
I have used this model from way back in my Jeep/tent camping days.. Stores easy in its own carry bag and fits under my truck back seat area. I can sit this on my dropped tail gate of the truck and connect directly into the trailer battery bank terminal. The long hose reaches everything from this spot.
I use this adapter from AMAZON to connect to the city water port to blow out my water lines in the trailer and then fill the P-TRAPS with RV pink stuff. With the tankless compressor the pressure is slow to build-up which allows to get to the spigots everywhere to drain the water out without fear of over pressure on the lines.
Great small footprint items to have around for my off-road trailer...
Roy Ken - Fresno_Tundra_DExplorerI've gotten by with a bicycle pump for 12 years. :)
44,070 PostsLatest Activity: Sep 18, 2026
