Cummins12V98's avatar
Cummins12V98
Explorer III
Aug 03, 2017
"POS" 68RFE !!!
Here is a post from the TDR (turbodieselregister.com)
Poor guy only made it to 612K before replacing his 68RFE.
"600k miles 2012 Ram 3500 Laramie longhorn
Just thought I'd post that my 2012 has 612k miles on it. Just replaced original 68RFE transmission with a mopar reman today. I hall cars (25k lbs combined) all day everyday for last 3 years. The truck has been awesome. No one believes I have original engine, turbo, etc. I'd hoped to get more out of tranny, but I'm told 600k is 3 times longer than it should last so $4000 installed is not bad I reckon. Of course it's had bearings, seals, ball joints, ujoints, and all of that a few times and the typical batteries, alternators, water pumps etc..., but it still surprises people that the engine and tranny have held up. Curious what y'alls experience has been. 3.73 gears and 4WD towing about 15k daily. Truck has auxiliary fuel, flat work bed with tool boxes, airbags so it weighs about 10k fully fueled.
All of the interior and electrical has held up well. Not your grand dads dodge. Anyway, your thoughts."
  • My 68rfe is around 290k. And it is deleted and tuned. Running 35in tires. Tows a couple times every week. Sometimes over 20k lbs. You don't read threads about 600k mile Ford 6.7s.
  • 600k on the original trans?!? :E
    Wow, that is a lot.
    Although I would have spent a little bit more and replaced it with a built 68RFE with a 3 clutch torque converter from Revmax, Suncoast, or ATS instead of just a stock reman.
  • Yeah -- I see alot of guys insisting that you've got to get the Aisen in order to have a reliable TV RAM. The 68RFE seems to also be fairly bullet proof and from reading alot of TDR posts seems to be less trouble shifting and with the hesitation problem.
    That said -- The 3rd gen RAM 48RE(RFE?) had a really bad reputation but I had mine gone through at 150K and the very reputable shop said it was all within factory spec - keep running the heck out of it.
