How do i check to see if i have Mold behind a wall in a newer model travel trailer?? Found surface mold on the bottom of a trundell bed( white fuzzy mold) and a white fuzzy spot on the carpet under th...
Do an interior pressurized leak test. It will find any and all leaks. Slide seals are a source of some leaks, how are yours? Since you may have a soaked floor or wall, pull up the carpet next to the wall and inspect.
