Babb01's avatar
Babb01
Possible Mold
How do i check to see if i have Mold behind a wall in a newer model travel trailer?? Found surface mold on the bottom of a trundell bed( white fuzzy mold) and a white fuzzy spot on the carpet under the table. The carpet under the bench seating on the side of the slide is damp and the wood along the bottom of the bench against the wall. Any advice, hoping not to tear the wall apart or how do i remove without tearing the wall apart.
  • Find and fix leak first. If you can dry out every thing fairly quickly, you may not get mold in the wall, if there is a cavity in the wall. Really depends on how long everything has been wet and the construction of the wall.
