92DakotaHD's avatar
92DakotaHD
Possible slide leak, input on a solution...
There is a gap at the front top corner of my slide when closed. There have been issues with water getting in the trailer in this area, I thought of just building it up with some caulk but wasn't sure if that was a good idea any input? One pic is of the rear of the slide and then the front for comparison.
  • It's bolted to the slide but need to crawl around inside and see if there is an adjustment there.
  • Can you adjust the slide on the side with the gap so it closes tighter?
  • install some 90 degree vinyl edging to act as a rain gutter. You can use double sided tape so no screws would have to go in the siding. You can use corner edging in the siding section and then cut it down to size with a table saw
