Wes_Tausend
Jan 10, 2014Explorer
jspringator wrote:
I would be anxious to hear reports of anyone towing with a hybrid.
Locomotives are hybrids, and they tow pretty well considering they only weigh a tiny fraction of all the "trailers". I could tell you a lot of railroad stories and how it is done.
But, if you are not joking about asking about Hybrids, I'm sure you are asking about a Hybrid pick-up such as the past Silverado, or Durango(?). I say past, because I believe they do not make them any more. But when they did, the Silverados towed just fine according to their GM website. The brake energy regeneration had little effect on the limitations of the multiple OEM shared modified hydraulic transmission. Not like our Prius all-electric driveline where towing would probably kill it.
The highway mileage was the same as conventional, but city mileage gained a bit from recovering braking during stop-and-go driving. It saved a little precious oil for our grandchildren and the fine folks in other developing countries. Long live America.
It would be nice to hear from an actual truck Hybrid owner. Maybe some of the Chevy forums has an experienced user.
By the way, shown below is a good example of the main reason for listed 1/2 ton load limitations... tires. Photo Courtesy of APT's earlier post in this same thread.
Load capacity can be improved by upgrading tires. Note that this photo shows that higher than typical "Load Range B" tires are used because the inflation pressure is notably increased. In other words, it is easy to gain 500# in 1/2 truck ton load capacity usually by just upgrading the passenger grade tires to better LT (light truck) tires. It's just like putting those rivets back in the airplane wing. Wings and tires hold the rest up.
Wes
