Huntindog
Sep 24, 2018Explorer
tracey5290 wrote:I had that converter. It did the same with the fan coming on with the lights. When I switched to LEDs, that stopped.... I replaced it later as those WFCOs just don't work as designed. They usually are stuck at 13.6 volts. Most people replace them because they want the boost voltage to come on.. I replaced mine because it would never go into float (13.2) which was too much for phoenix's summer heat and was boiling off my batteries.
New here...so thanks in advance for any help or guidance.
I have a 2012 Open Range 293R. It came with the WFCO 9865 converter. Since brand new, I would flip on the bedroom lights and the converter fan would blow. Shut the lights off and the converter fan would stop.
That was the only time I would ever hear the fan. Starting yesterday, I switched the bedroom lights on and the fan would start, in a few minutes the lights would start to dim and almost go out completely. Then I'd hear a high pitched squeak coming from the converter fan. I also have a 12V Deep Cycle marine battery that looks to be fully charged. I'm thinking that it is time to replace the converter, but I'm wondering why the fan turns on all the time that the bedroom lights are on, then turns off when I shut the lights off????
It appears that your WFCO has a problem. It isn't worth fixing. The power max I replaced it with was pretty cheap and actually works as designed. I suggest you do the same and just move on.
44,068 PostsLatest Activity: Jun 05, 2026
