tobydog927
Dec 28, 2015Explorer
STBRetired wrote:
Find out what else is on that circuit. Most houses do not have an outside outlet that is on a dedicated circuit. See what else doesn't work when the breaker trips. As Larry said, breakers will go bad. The more they trip the easier it becomes to trip them. Replace with the same size breaker, do not go bigger.
It's a ranch property, old, everything is quite strange on this property.
On the breaker box I'm hooked to, it has 3 x 20amp breakers. It's on a horse shed, appears other than my trailer that only lights on the horse shed are on the entire breaker box. There's lights nearby that I thought were on the same box but turned all breakers off and the lights stayed on. I'm not sure if this breaker box is a sub box from main house or part of garage's breaker box. Is it hard or safe enough to replace the 20amp breaker myself and see if that helps?
