tobydog927
Dec 28, 2015Explorer
STBRetired wrote:
How long is the extension cord? and what gauge? 10? 12? 14? If it is more than about 10 feet long, it should be a 10 gauge cord. Try turning you fridge off and back on. When the power goes out, it tries to switch to gas which could be why you are getting a check light.
Is the breaker panel protected from the weather? If moisture gets in there it can ruin the breaker.
50ft, I don't know what gauge "medium duty outdoor" I'm fairly sure it said.
I switched fridge off and on earlier, check light was still on as soon as I turned it back on. What about the leaking/melting inside fridge?
The breaker panel is on the outside of the horse shed, in the metal box thing. We've had a lot of horribly cold wind and some rain. Now that you mention it though, all my plugs and adapter things connected are all outside on the ground. I've usually had them covered as much as possible where they plug in together but the wind throws around my coverings and I'm sure they've gotten wet too but I assumed being outdoor things they'd be mostly okay..... :S
