Diplomat_St_Poo
Dec 28, 2015Explorer
As a temporary solution can you run a second extension cord for the electric heater? When we are camped where there is only 15 or 20 amp service we run a second extension out the window for the electric heater on a separate circuit.
Even if you are not turning anything on, the converter may be turning on causing the power to trip. Or the breaker heats up and trips.
Is there anyway for someone to show you how to remove the propane tank and have it filled. If the fridge doesn't work on power it may work on propane. Likely the heater element in the fridge needs replacing. Fairly simple process, elements usually cost less then $20.
Good luck.
Good luck.
