Diplomat_St_Poo
Dec 28, 2015Explorer
The converter in your RV basically does two jobs.
1) When you are plugged into electricity it converts a portion of the 120 volts coming into the RV down to 12 volts so all of the 12 volt devices like overhead lights and fan motors will operate without draining the RV battery.
2) It has a battery charger built in the converter to keep the RV battery charged.
A bad element in the fridge will not normality cause a breaker to trip unless it has a short.
Unless the second plug is on another circuit it will likely not help your power situation.
