tobydog927
Dec 29, 2015Explorer
herbhyde wrote:tobydog927 wrote:Boband4 wrote:
The OP has continously remarked that everything is electric, no gas-and it has been cold and windy. Could the electric side of the water heater be cycling on more? The water heater in conjunction with the space heater and electric blanket would probably overload a 30 amp circuit. Recommend the OP look for the water heater and see if there is an on/off switch.
I do hear the water heater often outside once I've had to reset the breakers after it trips. Even if I haven't used any hot water in hours or all day. I have noticed my hot water somewhat sprays/spits out of the tap in the kitchen at first occasionally, it never used to do that.
Do your suggest if there is an on/off switch to only switch it on as needed, like to shower? Not sure how long prior to a shower it would need to heat though, I will take a look for the switch today, if there is one.
Where does the water pressure come from??? An external hose(Well Pump)
or the water pump in the TT.
External hose. The hose or the hose spigot part from the ground had been freezing, I've almost completely finished wrapping it in foil & foam things and burried half of it.
