tobydog927
Dec 30, 2015Explorer
herbhyde wrote:tobydog927 wrote:
It could still be the breaker, sure, but it's been 24 hours now without a single power trip, since the water heater has been off.
I finished all the foil & foam thing over my outside water hose yesterday, woke up expecting water. Nothing. Giant icicles down the foam covered hose leading out from the trailer, lots of ice. Not sure why it's leaking there in the first place to make that much ice, but any suggestions?
Broken water lines due to freezing. You just made your problem a lot worse. You sound as if you are on a limited budget. Right now the trailer is not livable.
What water lines? Everything works when the hose is thawed out
