JShiv
Dec 12, 2017Explorer
Power loss
2012 Lance 950S with no power to the TV, antenna, or radio/CD player. Everything else works. All fuses seem to be good, although I am going to replace them tomorrow to be sure. I replaced the broken a...
D.E.Bishop wrote:A test light doesn't' tell the whole story . A test light will light with very low voltage . If there is too much residence in the fuse connection or at the appliance it may not operate . Check the volts on both sides of the fuse .JShiv wrote:
They are labeled, but perhaps incorrectly. I'll check resistance tomorrow. It almost has to be a fuse, since all the A/V is out and everything else is OK. I have some known good fuses on hand as well.
If you're going to the extreme of pulling and and checking the fuse with a meter, why not just use a test light and check both sides of the fuse for power? Wouldn't that be satisfactory and simpler than pulling all the fuses checking the continuity and then reinstalling them?
