Jimmc wrote:
Perhaps a naive question from someone who has never used a WDH and was wondering if a power jack was really necessary. Do you really have to raise the TV rear end using the jack? It seems like you could position the coupler over the ball and leave it high enough to attach the bars, then lower the jack and couple. That would require something a lot less than a 1000 lbs with a moderate weight trailer and should be do-able with a manual jack.
Sorry, but that would make it even harder to raise up the bars with the chains. They are all do-able with a manual jack but the power one just makes it easier. If you are strong enough and/or young enough you do not even need to use the jack at all. Just use your arms and the pipe - and be careful.
Barney
