SoonDockin
Aug 13, 2022Nomad
If I could fit a mini-split in my 1140 AF I would have already. Just no good place to put one that will have a clear air path.
You could just run from batteries, but they are pretty expensive too. Still Solar won't work at night so either way you need enough battery to carry you overnight. I have a 30 amp 12v-12v victron charger hooked to my truck that helps keep the batteries up while driving. We keep the AC on while moving and on all but the really hot days it will keep up fine with my solar. Last trip it was over 100 and I only made it about 5 hrs before I had to stop and fire up the generator. Drove the next hour with that on and was good for another few hrs. When its in the 80's, the truck and solar can keep up with the little cycling the ac does in days drive.
