valhalla360
Aug 14, 2022Navigator
CA Traveler wrote:
A air conditioner that draws 12A AC would require an inverter that draws 130A DC from the batteries and would require a large solar array, battery and inverter. Basically it's just not practical for a RV.
Instead use a 2000W gen or larger for your 30A RV to run the A/C.
To put this in perspective...
12a @ 120v AC, is 1440w. Assuming a 50% duty cycle (ie: the thermostat has it running 50% of the time), you will need around 17.5 kwh of usable energy in the battery bank.
- Lead Acid batteries can only use around 40-50% of the rated storage if you don't want to damage them.
- Lithium can use around 80% of the rated storage.
A 220amp-hr 6v golf cart battery is rated for around 1.3kwh...to get 17.5kwh of useable power, you will need around 26 batteries.
You will need around 18 100amp-hr 12v lithium batteries. Still a lot of batteries to find a home for and a lot of $$$$.
This is for modestly warm conditions. When it's hot, don't be surprised if the duty cycle is near 100%, so if you want to handle those conditions, expect to double all the numbers above.
Of course, you need to fill those batteries if you want to use them day after day. Let's round up to 20kwh each day as you likely will run the fridge, lights and other items. A good rule of thumb is you get around 4 solar hours per day. This means for every 1 watt of rated solar cells, you will get 4 watt-hr produced. To get 20kwh, you are going to need around 5kw of solar panels. Assuming 15w/sqft, that's every square inch of roof on a 40ft RV.
A mini-split can get some efficiency gains but if you want to just turn it on and get cool, it still needs a big battery bank.
PS: If you get a generator, go at least 3000w, so you don't have to mess about with sometimes it works and sometimes it doesn't.
