valhalla360
Aug 18, 2022Navigator
spoon059 wrote:
Couple of thoughts... I suggested a mini-split which would draw significantly less than 21 amps or 1000 watts. From what I am reading a 12K mini-split pulls about 4 amps at maximum draw and throttles down substantially from there. I've seen plenty of Youtube videos of people running mini-splits off 8 panel solar systems with larger battery banks. Its doable, likely for about the cost of a typical onboard generator.
I simply don't want to pay those prices to make it silent, so I'm leaning back towards a $1200 Honda 2200 for the occasional dispersed camping.
But, it is absolutely possible with a reasonable solar array and not nearly as expensive as your model.
The difference with inverter based mini-split units is they can adjust the draw to the output desired.
So if for a given rig at a given temp, it takes an average of 7500btu to achieve the desired temp:
- A 15k btu mini-split will draw power enough to put out 7500btu but run continuously.
- A 15k old style roof mount will draw power enough to put out 15k btu but run around 50% of the time.
Net effect is you need roughly the same amount of stored energy. Mini-split units might be a slightly more efficient but not a chance it's going to put out the same cooling btu at a 1/3 the power consumption.
