Jayco23FB
Mar 14, 2014Explorer
Premium Fuel?
In my area we have regular fuel 87 octane with ethyenol and premium 92 octane without ethyenol. My truck (2007 Chevy 2500HD 6.0L) does not NEED prem. fuel. Is there any issues running prem. fuel? I kn...
spadoctor wrote:
Do a quick search...federal regulations require ALL gasoline have 10% ethanol. As for using high octane than statd...it actually d damage in the long run as the higher octane burns colder causing higher deposits. In todays world there is no reason o design using higher then 87 octane. Hyundai engines run 10:1 compression on 87 as do most new cars. You can even lower the octane level used by introducing it slowly....the computer will adjust. It will result in slightly lower HP but no ill effects.
