SidecarFlip
Jun 05, 2017Explorer III
maxum1989 wrote:SidecarFlip wrote:
Been doing it for a few years no with no issues. I'll have to get out the Dwyer and see what it's pushing...sometime.
Don't understand 'getting the desired pressure' What is your desired pressure? Is it the same as my desired pressure or is your pressure different and what determines the correct pressure? I don't believe you know and I don't either nor do I want to.
Just enough pressure to escape from the compromised seal areas. Nothing more.
...very little air movement required.
I think you are reading way more into the procedure than is necessary.
Not trying to 'inflate' a camper like an inner tube, just get air movement (positive pressure to ambient pressure transition.
Don't make it complex. It isn't.
I don't do the 'what if stuff' I do the what is wrong stuff much better.
If you took my responses as being argumentative that was not my intent. You can use whatever pressure you like.
My desired pressure when I do this test at home is to obtain the same pressure that the Sealtech machine uses when getting this done at a Dealership. After all, this is the test we are trying to emulate isn't it? So why not use the pressure they use? It was tough to find it when I tried looking for it but eventually I found it. I do not remember where that is now though.
Not trying to be argumentative at all.
In my view, a little common sense prevails. Don't think that anyone using the home brew Blower Door Test would intentionally attempt to blow the windows out of their unit, that seems far fetched to me and I give anyone who does the test more credit than that.
Conversely, most folks don't have a manometer available so a bit of common sense is all that is required (in my opinion) at least.
Finally, knowing CW like I do and reading about the horror stories concerning CW's less than stellar service, I'd be surprised if the average CW technician even know how to use a manometer, let alone read the scale correctly.
I think you are making a simple procedure overly complex. All it take is some common sense to be successful.
If I wanted to argue with you, I'd do it via PM, not on a forum where everyone can observe and pass judgment.
It's not about passing judgment at all. What I posted about was a simple way to ascertain where your RV (and that includes ALL RV's not just TC's) have potential water intrusion points at. Nothing more.
I read literally hundreds of posts on various forums (I'm on more than one forum) about leaks and sealing seams and voids but most all those folks don't really know if their efforts are paying off because they really don't know (without a Blower Door Test) if and where it's actually leaking or not. Quite literally, you could be applying Dicor or Eternabond sealant to an area that isn't leaking and a few inches away, the water is coming in.
Only one way to find that out that I know of... Well 2 ways, Pay CW to do a Seal Tite Blower Door Test, or do it yourself. I'm for the latter because one, I'm cheap and two, if I do it myself, I know it's done right, to my satisfaction.
No argument at all. I'm a KISS person.
44,071 PostsLatest Activity: Aug 30, 2026
