Drew_A_
Aug 28, 2017Explorer
leoshats wrote:
Thank you, Drew A., for your prompt response. But anyway the hitch head is still tilted down ..., or is the 3P weight distribution jacks keep the head parallel (straight)?
Thank you!
When the jacks are used, they will locate and keep the hitch head at any angle, (within the range of motion of the hitch head).
If you need to use the strap system, you will need to figure out a way to immobilize the hitch head at the required angle for hitching up. I can't see how you could ever hitch up if the head is free to pivot as it hangs from the ball.
good luck.
44,071 PostsLatest Activity: Aug 16, 2026
