myredracer
Sep 19, 2017Explorer II
They make lube specifically for balls (says with poker face). I use the Reese white grease posted above on ours. Still have the little container of it I bought 5+ years ago. Lasts a long time.
Good point on grease attracting dirt and causing wear but I'd rather lubricate the metal parts that rub together like they do. You can always replace a ball but replacing a worn out coupler isn't easy. Our truck is used primarily for towing so the ball mostly sits exposed at a CG or at home. Any cases out there of balls/couplers being worn out from using or not using grease?
I always leave our Reese DC shank/hitch head in place because it bolted down with a Blue Ox immobilizer. I periodically check the sockets for dirt & debris and clean as needed.
Used to have a stainless steel ball but had to replace it with a ball with 1" rise which has ordinary plating. Not sure if s/s creates more or less friction or maybe galls?
