2edgesword
Jul 04, 2013Explorer
Here are some of the things Atwood suggest as possible cause of burner not remaining on and solutions:
Improper gas pressure -- Set inlet pressure to a minimum of 11? W.C.
with two or more appliances running
Improper air adjustment -- Adjust main burner air shutter approximately 1/4 open
Partial blockage of main burner -- Remove blockage
Partial blockage of main burner orifice -- Clean or replace orifice
Flame spreader misaligned--Re-align spreader or replace main burner
Blockage in āUā tube --Remove blockage
Poor gas supply -- Replace gas supply
Exhaust grille blocked --Remove blockage
Improper main burner alignment --Re-align main burner, main burner
orifice holder and gas valve
44,056 PostsLatest Activity: Nov 19, 2013
