btd35
Jul 22, 2013Explorer
Go through connections first. Start at the batteries cleaning terminals, and work your way through others at the inverter. It may also be somewhere in a junction area you don't know is there. Often major connections are made behind light fixtures, or any pannel that will open up in RV's. Twist wire nuts tight etc. Concentrate on grounds. Very likely something is loose, or dirty.
44,055 PostsLatest Activity: Dec 23, 2025
