Longtrace
Jul 23, 2013Explorer
You fail to mention the power source. Is this problem when using shore power? Onboard power?
The battery and all the battery connections should have no effect on available power when using shore power because the charger/converter is supplying the power for all the 12V stuff and the shore cord is supplying power for the 120V stuff.
Here I get confused. An inverter uses battery power (12 VDC) to create 120 VAC - like what the shore cord supplies. If you do have an inverter and it's big enough to run the air conditioner, you will need a _big_ battery bank.
Once we know the power source when the problem occurs, we should be able to do a much better job advising you on where to look for problems.
Fleeter wrote:I suspect "AC" means "air conditioner", not "alternating current". On most trailers, the air conditioner gets it's power only from the shore cord. If this is the case with yours, measuring the battery voltage when lights dim isn't going to indicate much.
...and sometimes the AC will go off. Even with the AC off the lights on the 12 volt inverter system will go very dim
I'm thinking maybe there in a problem with the inverter
44,056 PostsLatest Activity: Nov 19, 2013
