MFL
Dec 14, 2020Nomad II
One thing to add, concerning hard to release, is that it can be a tight fit, under certain conditions, and using a thick lube plate. There are thinner lube plates available, from several sources.
fj12ryder gave a good tip to open jaws, when there is pull from truck, holding the jaws. :)
Above, from Cummins 12V98, also good idea, as real people will answer, and will have/get the information you need.
Jerry
Jerry
