Anmacc2ExplorerApr 29, 2016Problem with iRV entertainment centeriRV radio/DVD won't turn on. Press the power switch and nothing... Checked the fuses and breakers in the panel and all are good. Is there an inline fuse in the unit? It's wired directly in and not a p...Show More
bobndotExplorer IIIApr 29, 2016Did you unscrew the unit and check the wires behind it ? Maybe the hot lead disconnected ?
Related ContentReplacement for Jensen Entertainment CenterUpgraded Entertainment CenterOutside entertainment centerEntertainment Center UpgradeRemoving overhead entertainment center
