Let me see, where do I start?
Fresh water tank drain valve pipe connection leaking.
Fresh water hose kinked at 90 degrees on the outlet side of the pump.
Check valve in the black tank flush line installed backwards.
Stripped screw holes for cabinet door hinges.
Calking not covering many screws anchoring the trim anchoring the rubber roof.
The self tapping screw anchoring the ground wire to the trailer frame broken off.
Screws anchoring roof ladder not completely seated and a couple of screw holes stripped out.
Cabinet drawer slides attached with only one screw on each end of slides leading to misalignment of the slides.
The trailer frame was welded on after the plastic underbelly seal was installed which melted enough away to expose the fiberglass batting insulation.
This and more on my 2016 ARCTIC FOX 25R TT.
Our 2006 Sunline 2075 TT was flawless with quality craftsmanship through out. Served us well for nine years until we wanted a little more room.
