Ralph Cramden wrote:
Fresh water tank that fell out due to undersized supports.
Scratched exterior aluminum trim.
Scratched windows.
Slideouts and slideout openings built out of square.
Screws over tightened and stripped throughout.
Water leaks in plumbing from the use of pex fittings and crimp rings on flexible tubing where barb fittings and hose clamps should of been used.
Water damage incurred during delivery between factory and dealer due to sloppy seal installation and sealant.
Razor cuts in vinyl floor.
Entry door out of alignment.
Seams pulling apart on upholstery.
Missing roof sealant.
Factory installed vent covers mashed into fresh sealant causing roof leaks.
Bent trim at slides and lower fascia.
Screws too long used on inside that pushed outside fiberglass out.
Loose electrical connections on shore power connection.
Staples shot into paneling with nothing behind.
Peeling vinyl wall covering.
Schwintek slide racks installed crooked resulting in binding.
Interior caulking done by 3 yr olds.
Loose traps at sink drains that leak.
Peeling laminate at counter top edges.
Warped dinette table.
All of the above, and more, on an ordered unit when it arrived at the dealer which we refused to purchase after a 12 week wait. Undoubtedly the dealer pawned it off on some other sucker.
Geeze Ralph, no wonder you don't like the n'other forum'. Understandable...lol
I must be very, very lucky, I also ordered mine and picked it up from a dealer not local to me and have had absolutely no issues at all. No stripped screws, no wonky trim, no leaks, everything works fine and everything actually lines up.
