1320Fastback wrote:
Water leaks around window and exterior light, soft shower floor due to no support, electrical outlets mounted to vaneer only and not studs.
Be careful about the soft 'unsupported' shower pan floor. Reason being, the flex in the pan floor will eventually crack the moulded in flange around the shower drain and it will leak and ruin the floor below the pan. 2 fixes. One, add support from the bottom (a job to get in there and correct it or Two, add a teak shower mat like I did. The teak mat spreads your weight over the entire area and lessens the 'flex' and prolongs the life of the pan flange and provides a dry, non slip surface too.
Pretty common issue in RV's today.
