Crdodd
May 16, 2014Explorer
Problems removing water heater
Due to poor winterization, my tankless water heater busted. I am trying to remove the unit, but having problems. I disconnected the gas line, but do not see any place to disconnect the other lines. It seems it should pull out of the hole and then give me access to the connections. But it won't pull all the way out. Help needed.
I have the new unit already. The connections are on the back side except for the gas line that passes thru the back wall. I am really confused. There is no panel to remove without cutting a hole, so there is no designed access to reach the back side.
