thetundrawolf's avatar
Sep 17, 2014
Product warning: Hopkins tail light converters
I just wanted to warn everyone about Hopkins tail light converters, available at Wal Mart.
I moved to Arizona not too long ago. I still have stuff in California, including a 4x8' trailer I let a friend borrow. (For about 8 years...)
I got the trailer back, and thankfully I used to live in the rural desert, so I took dirt roads home. I brought an older Japanese truck that gets excellent mileage for the eight hour drive, as I do not have a lot of money.
While in Arizona, I realized that this mini truck has separate tail and turn and brake lights, necessitating a tail light converter.
I live in Prescott, AZ, which is a horse and ranch town. The weather here is excellent, as is the political climate if you believe in individual freedom. (Just thought I'd throw that in there!)
I called C-A-L ranch stores, and Tractor Supply, to see if they had one- neither of them had the converter. Finally I went to Wal-Mart and found a Hopkins tail light converter for about $25. I bought it, wired it in to my truck, actually I soldered every connection, making sure they were solid.
Well, I get to California, and I discover the trailer lights are a total mess. I hook it to my truck and take dirt roads back to where I had been staying.
I manage to re wire the lights, and hook it to the tail light converter- and I get running lights... but nothing else. Just the faintest, smallest glow for the turn and stop. Barely noticeable, even in the dark!
Well, I went to visit a friend and brought the converter with me, expecting to exchange it while hanging out with him.
We exchanged it, I visited some family, and I drive back to the desert. I hook the new converter up and...
Same problem. It must be the ground, so I took extra precaution to clean it. I take jumper cables and make a clean ground, and hook it directly to the converter. Still. No lights.
I check my connection with a test light, an 1156 single filament bulb in a socket with wires attached.
Every connection I made was proper.
It is dark, now, and approaching ten O'Clock. I have to leave the next morning.
So, i drive to four different cities, using half a tank of gas, from Wal-Mart to Wal-Mart, until I find the one tail light converter one store had in stock.
Of course, when I got there, there returns department was closed, so I had to shell out another $25.
I try it in the parking lot.
Same *&%! THING. Tail lights and running lights work great, but turn signal, and brake lights, nothing but a tiny, faint glow.
I can't take it back. It's 11 at night and I am exhausted, with an 8-10 hour drive home early the next morning.
I end up returning home, and sleeping in from the exhaustion and frustration.
I left the next night, after resting.
Here's the interesting part.
I put two older pickup trucks I had on Craigslist up for sale. I get a bite immediately, so I begin clearing out the bed of one of them to show a potential buyer.
Lo and behold, a tail light converter I had removed from the truck years ago! It was at least thirty years old. Instead of having nine wires, like the Hopkins tail light converter, it only had five. No ground.
I hook it up to my original wiring... AND IT WORKED.
It got me home!
I am enclosing pictures of the Hopkins tail light converters and also the older converter that actually worked.
Cliff notes: Went across two state lines, five different cities, purchased three Hopkins Tail Light Converters, NONE of them worked.
Found a thirty year old converted in the back of an old pickup truck that worked perfectly.
Avoid Hopkins products at Wal-Mart.
Pics:
Culprits, all had the same problem
The one that worked! Dirty, old converter that worked
  • The output of a Hopkins 48895 is 2.1amps. You bought the wrong converter as a single 1156/1157 trailer light would require 2.1amps...
  • I'm sorry guys. You have no idea the hell I went through. It might seem like I might not have had it installed right, but I did. (As evidenced by the fact that an old converter worked perfectly using the wiring that I did not change) I was and am so frustrated with the product. I am not mad at Wal-Mart.
    Hopkins tail light converters are junk.
  • MM49 wrote:
    I would suggest that you have an installation problem. Hopkins is a very well respected company in the RV business,
    MM49
    Did you read what I said? Really? I went off of my original wiring and the older one worked. I double, triple, and quadruple checked my wiring. Using an 1156 bulb and harness to simulate what I did.
    Going from the input wires I had a BRIGHT LIGHT from the 1156.
    Going OUT OF THE CONVERTER I had dim, almost unrecognizable light. I used an artifical ground just to make sure that part of the frame, what was also used to tail light grounds (I used the supplied connector with the converter. I cleaned the metal to a shine.) and still no output from all three converters.
    Well, you can believe that. If you get one and have the same problem, it's not on me. I warned you.
  • enblethen wrote:
    Sounds like a Hopkins problem and not a Walmart bashing problem.
    Tail light converters are available at my locations other then Walmart.
    All the running around didn't do a thing. Why didn't you go to O'reilly's, Autozone or Napa?
    Did I bash WalMart? No... I said it was available at WalMart.
    I am saying the Hopkins product is no good.
    I believe I went to autozone, who did not have it, so I ended up going other places. I am not bashing Wal-Mart! Where did you get that?
  • I seriously dislike those tail light converters. They are not powered at all...which means they are not circuit protected.
    Get a Curt or Tow Ready or any other brand powered tail light converter and this problem goes away. And you will have BRIGHT Trailer tail lights that don't flicker or flash or go dim or anything else those others have.
    The powered tail light converters use the TV tail light signal just to direct power. They converter sends power from the vehicles batter to the tail lights.
    Thanks!
    Jeremiah
  • I would suggest that you have an installation problem. Hopkins is a very well respected company in the RV business,
    MM49
    yep
    x2
    bumpy
  • Sounds like a Hopkins problem and not a Walmart bashing problem.
