Hitch_Pin
Jul 07, 2013Explorer
westend wrote:
ProflexRV technical data sheet. At average summer temps, the sealant can probably be worked successfully up to about 30 minutes. After that, it will be skinned over and be miserable to work. I usually work the bead into the joint immediately after I apply it since it is thicker than most sealants and I won't have to revisit a location.
Does it keep good if you don't use it all up at once, or does it dry up in the tube?
