westend
Jul 07, 2013Explorer
Hitch Pin wrote:It does not keep good in the tube, probably about a month with the tip sealed and in ambient temps. I've seen where others refrigerate it and have success. I actually use Geocel 2300 instead of ProflexRV. The products are nearly identical but I buy through a roofing distributor and prices are cheaper than RV parts distributors. Geocel 2300 has just a tad more elongation strength than ProflexRV.westend wrote:
ProflexRV technical data sheet. At average summer temps, the sealant can probably be worked successfully up to about 30 minutes. After that, it will be skinned over and be miserable to work. I usually work the bead into the joint immediately after I apply it since it is thicker than most sealants and I won't have to revisit a location.
Does it keep good if you don't use it all up at once, or does it dry up in the tube?
