Hemi_Joel
Apr 04, 2020Explorer
THe spark arrestor was attached to a flange at the exit of the muffler with a couple of little metric screws. Since I need to attach the exhaust pipe to it, I drilled and tapped the flange out to 1/4-20.
Then a made up an exhaust pipe flange out of some 5/16" steel plate, and welded a 3/4" pipe nipple to it, at just the right length to reach thru the shroud.
I ground the mounting surface flat and smooth for a good seal.
44,071 PostsLatest Activity: Aug 30, 2026
