Old-Biscuit
Mar 27, 2017Explorer III
IF you go the heat route.......
Remove the tstat rubber cover
Remove both sets of t-stats
Pull the 120V and 12V wiring inside over to the left as much as possible away from heat
I prefer some penetrating oil, some taps with wrench/hammer just to jar it so penetrating oil can seep between thread, let soak for at least an hour ----couple shots of oil/whacks while waiting
Then try to 'tighten' it a bit before trying to loosen
A 'cheater pipe' may need to be part of the equation of removal.
44,027 PostsLatest Activity: Mar 05, 2025
